The pressure is fine and like others have said, you probably have a restriction. First thing to look at is the aerator on the end of the faucet. Take it off and turn on the water. Next would be the shutoff valve under the sink, close it and open it. If this fails, turn off the water upstream of the valve (probably have to turn off all the water in the house), remove the valve and affix a hose into a bucket and have someone turn the water back on for a few seconds to see if the valve was the problem.
I had the galvanized pipe corrode inside to the point that it was totally blocked. I hope you have better luck than me.
