Is 52 celcius ok temp. for a cpu?
pitupepito2000
1,181
Hi,
I have a new computer and today when I came from work I checked the temperatures of the CPU and they were 52 degrees celcius. I was wondering if this high temperatures harm my cpu or not? also, What temperatures would harm my cpu?
My cpu is a AMD xp 1800+
:confused:
jarsoffart
1,832
52 degrees Celsius is fine for your CPU. I think around 70 degrees Celsius its bad. It also depends on how you take the temperature. I get around 50 degrees Celsius measured by my Abit KR7A.
daywalker
189
I have an AMD Duron 1Ghz, i also have my case open and my temps right now are 49C for the CPU and 34C for the motherboard.
Your temps are just fine. Have no worries.
Buz2b
4,619
Just a quick note here. For those running ~50c+, it would seem that those are "Idle" temps. If so, how high do they go under "load". That could be a problem and you should do a "Prime95" or other form of stress test to see the results. Just a suggestion, not trying to have you push the panic button.
Alphazero
1,057
52°C is just fine, even for an idle temperature. 60-65 is where you should start worrying.
