Is 330W power supply enough?
rmcohen
8
Hi guys,
I'm intersted in purchasing the Antec Performance Plus Plus660 that comes with a 330W power supply. I'm just concerned that 330W is rather anemic. I would appreciate some feedback on the this amount of wattage for the following non-overclocked system:
Athlon XP 2000+
Abit NV7-133R MB
2 x WD Special Edition 80GB 7200RPM with 8MB buffer
2 x Crucial 256MB
Gainward GeForce 4 Ti4200 with 128MB
Plextor PlexCombo drive
floppy drive
Thanks for reading,
Robert
yakko
25,455
For what you have listed it is fine. The question of it being enough comes in when you tells how many and what size fans you have.
ThisIsMatt
Banned
Aug 4, 2000
11,820
You'll be fine. Having a decent power supply is good, but I think a lot of people here go way overboard. Having some extra headroom is good, though, but no need to overkill. That PSU is a pretty high quality one if I'm not mistaken -- I think a lot of people may have been burned by using no-name 300/350/400W PSU's to the point where they'll tell you only a 400+W PSU will do...not so.
A friend of mine is running a very similar setup to your's, although with a 4400ti and an additional dvd drive on a 300W enermax.
I was running:
asus a7v133
Tbird 1.4
2x256MB
40gig 7200
80gig 5400
nic
floppy
sblive+5.1
modem
cdrom
cdrw
dvd
2 case fans
all on a 235W sparkle PSU (they make solid PSU's). I didn't want to push it, though, and have since gone to a 350W Sparkle and am using an internal zip drive now as well.
Another friend had:
Abit AT7
XP1900+
4 x 40gig 7200 striped
cdrw
dvd
all on a 250W dell psu that only put out 150W 5v+3.3v combined.
So, I think you'll be fine :)
rmcohen
8
Thanks for the quick feedback guys.
Yakko, my fan power requirements are also low. I will have 4 fans. All will be Panaflo 80 mm L1a's (or at least the BMG Micro version). I will have 2 at the front of the case, 1 at the rear of the case and 1 on the heatsink.
bozo1
6,364
It will be fine. Fans in most cases suck less than 5 watts each which is negligible in the scheme of things.
mechBgon
Oct 31, 1999
30,699
The TP330 does supply just as much 3.3V power as the PP412X does: 28 amps. It actually supplies 8 amps more on 3.3V than their 350W PP352X does. So if you're going to get a PSU, that looks like a good one all right.
chillysalsa
11
Sounds like You'll be fine. I'm running even more stuff with a 300W.
The AMD website has a whitepaper on calculating the right PSU for your system, look under recomended power supplies.
Kindjal
750
You can take a look at my T-Bird Rig and see that I have everything running fine with the TP 330W PS.
I have five 80mm case fans (hated to see all those spots look empty :) ) plus all the other usual PC hardware and she purrs right along.
I see a lot of talk about these huge power supplies but I don't plan on arc welding with my PS.
OracleMan
I'm using Antec 300 watts PS with the following specs:
4 80mm fans, 2 small fans fit in pci slot, cd-rw, dvd, seagate scsi160 10K rpm hd, maxtor 7200rpm hd,
alpha 8045 HS w/ 80mm fan, scsi adapter, matrox RT2500, ATI all-in-wonder.
It runs fine with 300 watts. 330 watts should be fine.
BigEdMuustaffa
1,361
Isn't it Watts = amps x volts.......examples:
So a Panaflo 80mm fan like the one i have is .1A and 12 volts....so wouldn't that make the fan 1.2 watts?
on the 12 volt rail that is. A maxtor 7200 rpm 40 gig HD draws 3/4 amp on the 12 and 1/2 amp on the 5 so that's only
8watts and 2.5 watts no? So when you add all your parts up.... that will tell you what you need or don't need.
