Is 32-bit color possible in Midtown Madness 2?
jakobkraft
1,011
I'm sure this has been asked before somewhere, but I didn't see anything when I searched. Was wondering if there was any way to change from 16-bit to 32-bit - at lower resolutions, the graininess of 16 is kind of annoying but easier on fps.
Any help would be appreciated, thanks....
igowerf
7,697
I don't think 16 bit color would make it grainy. It's probably just the lower resolution.
I tried googling about it and it seems like 16bit is the only option.
jakobkraft
1,011
I figured....thanks anyway for looking:)
BFG10K
22,709
3,004
Set your desktop to 32 bit colour and the game should automatically run under 32 bit mode (assuming it doesn't specifically request 16 bits).
