Is 2megs a normal wireless xfer speed?
Informant X
840
Greetings,
I'm really new to the world of networking. Have been able to figure out how to do most of what I want on my own. Setup homegroup, setup file sharing and permissions etc but I don't know why my xfer speeds aren't too fast, or if this is normal. When xfering files from one computer that's directly connected to the router and another computer that's wireless I get a xfer speed of around 2 megabytes a second. Is that normal or should it be faster? Both computers are using Windows 7 64 bit. Below are links to what I have.
GIGABYTE GN-WP01GS IEEE 802.11b/g PCI Wireless Adapter Up to 54Mbps
http://www.newegg.com/Product/Produc...82E16839121008
NETGEAR WGR614 IEEE 802.3/3u, IEEE 802.11b/g Wireless-G Router
http://www.newegg.com/Product/Produc...82E16833122016
So I'm just wondering is my speed normal? Would using different software on my router help out? Maybe flying tomatos?
dawza
921
That's pretty much what you'll get with wireless-G. I don't know if I've ever seen a peak >2.4MB/s, and sustained is generally 2.0-2.2MB/s (this is using FTP).
theevilsharpie
2,322
14
That's about right. You may be able to bump it up slightly if you make the wireless network a g-only network, but don't expect much.
Emulex
9,759
wireless rule of thumb: make sure your nic and router use the same chipset. for every router chipset there is a matching nic/usb chipset - usually - made around the same time.
atheros to broadcom = not good.
this gets far worst with 802.11N :(
