is 250 watt power supply enough
bacillus
14,517
may or may not work depending on the quality of the psu.
also depends on what else you've got in your box. :)
Hobbzilla
159
you're pushing it.. check out amd's recommendations.
Link
It also depends on other things.. Graphics card, # HDD/CD/DVD/CDRW, PCI devices, fans, internal laser security nets, etc.
Why chance the reboot & BSOD/Lock-ups? The socketA will be around for a while.. go for at least a 350W if not more.
Pabster
16,986
I'm using a Deer 250w on my 750 Duron box, and it's plenty for that (only 1 hard drive and a GeForce2 MX/400 sucking juice) but for any Athlon I'd recommend 300w, or better yet, a quality Enermax 450w+ ...
Mem
21,476
13
If I had a 250w PSU I think right now I would get the best I could afford that would last for the near future as well,so Enermax 350w or 430w would be my choice as well .
Btw PSUs are not expensive & I think they are a good investment if you buy a quality one,especially with a power hungry T-bird like yours.
Alphacowboy
482
My system had a 250 from the factory... if you read my system profile you will see what I am talking about, but I yanked it and replaced it with a 350Watt... runs beautifully!
PS... by the way, how do you get the link in the signature to go directly to you "rig" profile?
madthumbs
Banned
Oct 1, 2000
2,680
Quality is more important. A good quality one should be ok at 250W for most users. A cheap one can cause a fire, major instability, smoke, etc... An underpowered one just does things like booting you to the windows desktop from an intense game and less serious stuff. I use an Enermax 350W for all I've got... see sys specs. No problems at all.
