I don't know for sure, but I would think it would be OK. Most power supply fans I've seen are pretty quiet, which means they must be similar to what you are using.
My best improvements in PS cooling have been to cut out the stamped metal grille that blocks half the air and retrofit a better wire fan grille- improves CFM and cooling very well- you do have to open the PS, so be very careful.
