Is 128bit Color going to be the next big thing?
magomago
10,973
14
I was just wondering...to me the last big deal was BumpMapping vs AA with Geforce2vsVoodoo5 showdown. Everything else just seems to come from that (though I guess AF made a splash but nothing as huge...)
But I rembember previews of the the 9700pro showing 32bit vs 128bit color and I was impressed by them...but obviously it made the card 4 times slower in 128 bit color....
And like I earlier said everything so far seems to be "perfecting" whatever we have had...so does anyone also agree that 128bit color is the next big thing, or are there dissenting opinions?
rbV5
12,632
Internal 128bit floating point precision is not 128 bit color, you are still only "seeing" 24bit color.
Genx87
41,091
513
I dont believe the R3.xx cards atually render in 128bit. I believe it is all done at 96 bit no matter what the color depth.
Nvidias FX series can render in 12bit(integer), 16bit (partial precision DX9), and IEEE 32bit.
In a way the R3.xx is good and simple. And another way it is kind of less flexible.
Do i think 128bit color is the next big thing? Honestly I doubt it for gaming........ DX9 Full precision is 24bit so I highly doubt game developers will use the IEEE 32bit option from Nvidia. I honestly think for the near future 3-4 years 16bit FP color will become the norm.
TerryMathews
128 bit color would be ~3.5x10^38 colors. I don't think the human eye can even differentiate between that many colors...
Ronin
4,563
server.counter-strike.net
Matrox Parhelia's 'have' 10GB color for the desktop, but you'd never see the difference. It's really not something your eyes would be able to differentiate from.
modedepe
3,474
Next big thing..no way. I'm with schaden, I can't tell the difference between 16 and 32, give me 128 and I won't see any difference either. Unless I'm completely abnormal, I doubt others would see much of a difference with 128 either.
Pete
4,953
You must be misremembering. The 9700P shouldn't be 4x slower in 128-bit, as it's not a linear fall-off, nor are you even talking about the same things. The 9700P processes both 16-bit ints and 24-bit fp's (24b R, G, B, A = 96-bit) on the same hardware, so there should be minimal speed difference. And the cards with 128-bit floating point shaders still output to 32-bit buffers, so you're not going to see more than 32-bits (24 plus alpha, really) onscreen. Surely Anand covered this in one of his DX9-compliant video card previews.
I can certainly tell the difference between 16- and 32-bit color. If you can, you must be red and green colorblind, or haven't played many FPS games with smoke effects.
And yes, I think (128-bit/IEEE32) floating point shaders is The Next Big Thing in 3D.
