Is 12 CFM enough for a CPU fan?
nobb
237
Hi.
I am thinking about replacing my current cpu fan with a Vantec Stealth 60 mm. According to the manufacturer, the air flow of these fans is only 12 CFM. I was wondering if this would be too low and cause overheating problems. I am using an Athlon 3000+. Comments would be appreciated. Thanks.
Fullmetal Chocobo
Moderator<br>Distributed Computing
Moderator
May 13, 2003
13,704
7
No.... I see absolutely no reason to go below 25, and 35 is better. At 50+, you really start hitting diminishing returns for air cooling. So I think the best thing is to get a 55 CFM rated fan, and put it on a fan controller to control the temp / DB as necessary.
JEDIYoda
33,986
3,321
avoid the Vantec stealth at all costs...it will be quiet for a few days then all hell will break loose...its a loud fan compared to the CoolerMaster fans and others..
imported_rod
1,788
12cfm on the stock heatsink won't be enough.
If you really want to minimise noise while keeping temp's down, you should look at getting a new heatsink and fan. If your look around, you should be able to find a thermalright XP-90 and a low speed 90mm fan for under US$40.
RoD
cyberknight
378
yeah consider getting a new 3rd party heatsink/fan.
and if you want a quiet fan, do not get Vantec Stealth. They are crap low quality fans with a lot of motor noise and clicking.
RallyMaster
5,581
I believe the common suggestions are Nexus, Panaflo and Cooler Master but since you're looking at a 60 mm, I don't think those apply. Whatever you do, avoid the Thermaltakes. They may say they're a very quiet 19 dbA but when you put them inside your comp, they're going to be something like 38dbA. They'll only seem quiet to you if you dwell inside a large computer store in China during the day.
Edit: From that website, the 80 mm Zalman looks tasty.
