Question Is 1080p not enough for 27 inch monitor?
hardcore_gamer29
932
20
i have three options which one should i choose? i heard that text is fuzzy and unclear on 27 inch 1080p in windows 10?
Samsung 27 inch (68.6 cm) Curved Bezel Less LED Backlit Computer Monitor - Full HD, VA Panel with VGA, HDMI, Display, Audio in, Heaphone Ports - LC27F591FDWXXL
LG Ultragear 27-inch IPS FHD, G-Sync Compatible, HDR 10, Gaming Monitor with Display Port, HDMI x 2, Height Adjust & Pivot Stand, 144Hz, 1ms - 27GL650F
Samsung 24 inch (60.4 cm) IPS, 3 Side Bezel Less Flat LED Monitor (Dark Blue Gray) 75 Hz - LS24R356FHWXXL
VirtualLarry
56,548
10,171
1080 streaming getting pixelated? That's mostly down to your ISP and network connection.
But a video stream @ 1080P, playing back on a 1080P digital display, should NOT ordinarily be "pixelated".
  • Love
Reactions: hardcore_gamer29
blckgrffn
9,288
3,429
www.teamjuchems.com
THNX FOR HELP BUT ALREADY BOUGHT MSI G27C4 YESTERDAY :0
That's OK, the 1200 vertical pixels cuts down your options *a lot* - enjoy your new monitor.
Personally the sweet spot for me on text is ~25" 1440p/32" 4k, but my main gaming monitor is 1440p 32". Different use cases and personal preference is a huge part of monitor selection.
So choose to enjoy what you ordered :)
mindless1
8,348
1,552
You can't run a 1080p monitor at higher than native resolution. Nvidia control panel shouldn't even give you the option to do so.
You can run one at lower than native resolution but that is best avoided, looks badly blurry and the only good case for that is if gaming and the video card is too low in performance to maintain good framerate at the higher native monitor resolution.
I would have tried to stretch the budget for a monitor with higher resolution than 1080p no matter what size it was... unless built into a vehicle and only used to watch movies during long trips, then 1080p seems just right.
VirtualLarry
56,548
10,171
Sure you can, "virtually", with Desktop super-sampling. AMD calls theirs VSR "Virtual Super Resolution", NVidia calls theirs "DSR".
I've used it to boost my 4K UHD screen resolution from 4K to 5K, it works mostly pretty-good, but makes the text even harder to read than native.
Maybe that's what he meant by "blurry text", he was using VSR/DSR on his screen?
mindless1
8,348
1,552
^ That would be a virtual mess. ;)
Granted it's a lot less of one on a display with a lot of pixels already so the amount of virtual desktop off-screen is a lower % of total than using a 1080p except maybe 1920x1200.
A higher resolution monitor is worthwhile, only downside being that it's hard to go back.
I had my 4K TV-monitor fail a few weeks ago, and didn't want to break up any other system-monitor combos so grabbed a spare 24", 1080p monitor to use till the replacement arrived. UGH! It was horrific working 24" and 1080p. Luckily the replacement arrived in two days. #firstworldproblems
hardcore_gamer29
932
20
i can still do it from nvidia contol panel there are options enabled not disabled max i can go is 3840x2160 :)
hardcore_gamer29
932
20
no regarding blurry test i used only native resolution only
VirtualLarry
56,548
10,171
Define "stuttering" please. And list the rest of your machine specs, and the speed and type of your internet connection.
I didn't look up that monitor, is it a VRR type? Maybe there's some settings in Windows that might help, maybe it's VRR when watching videos, which to me would seem like a bad idea.
Of course, if you're dropping frames because your PC is too slow, or your internet connection sucks, a new monitor is not going to help you.
mindless1
8,348
1,552
i have installed it and first of al it is uncomfortable as i am near to screen... what should i do please help
Back away from the screen a little bit?
Wear sunglasses?
Turn the monitor off?
Put a blanket over it?
Put it face down on the desk?
Turn the brightness down?
Spin it 180' so you're facing the back?
Turn the PC off?
See an eye doctor?
"The problem is all inside your head", she said to me,
"The answer is easy if you take it logically,
I'd like to help you in your struggle to be free.
There must be fifty ways to leave your monitor"
Get yourself free!
hardcore_gamer29
932
20
other specs are:
i5 2500k
asus gtx 1660 ti 6gb
16 gb ram
seasonic gold psu
although netflix felt like it is screen tearing i would say but in vlc player there was definetely lag very much lag not as smooth as my old monitor by the way i need to mark this thread as solved as i have repacked the monitor and returning also GAME WORKED EXTREMELY SMOOTH EXTREMELY NO PROBLEM AT ALL
VirtualLarry
56,548
10,171
You're kind of like a friend of mine. His monitor died. So I got him a replacement from a recycler. He complained that it was making his PC slower. (Of course, a monitor cannot do that, it's just an output device.) So, I took back the monitor that I had gotten him, and got him a widescreen 16:9 monitor from the same recycler. I guess he was happier? Some people are just "sensitive", for reasons unknown. Maybe it's all in their head, maybe it's not. I cannot say with certainty.
Just know that most people don't have the same problems that you have, with monitors, OP, and that possibly there are some software settings that affect video playback (or choice of playback software, did you try other playback software?), and that your experience could have been different.
Edit: To add, you might need to get some "computer glasses", if you are having that many problems with LCD monitors. That, and turn the brightness WAY down.
hardcore_gamer29
932
20
i used neflix HD on edge browser before and after this new monitor there was visible stutter i guess i am better off with 24 inch only until i get intel 10th generation :)
