Irritating beeps help please.
Brightsword
99
Just installed XP pro...when I log into my admin account, all is quiet and fine.
Yet when I log into the user account I made, while it is loading the systray just before it is finished loading all settings there are 3 REALLY irritating beeps every time. Can anyone tell me what it is and how to get rid of it? On my other 2 computers I do not have this prob...same motherboard, processor and ram in all of them...and on my previous install on this computer no noise..thanks..t
LTC8K6
28,520
1,575
Sounds like some sort of alarm. Look in your BIOS for alarm settings maybe?
Brightsword
99
No it is not an alarm...
As I noted, there is NO beep when I log into the admin account, only when I log into the user limited acct. I just did a clean install and same thing. If it was an alarm it would go off on login to the admin acct too...
I only beeps just after login while it is loading icons in the systray.
Is there something in XP that makes this sound perhaps to let you know you are logged in? if so can it be disabled? just installed xp on same exact system on diff computer and does not do it...thanks..t
Brightsword
99
BTW, I changed that user account from limited to administrator and logged in and no beeps....so it has something to do with the type of account..I just want the beeps gone!!!>..thanks..t
