I'm trying to install my ethernet card on my computer for use while I'm here at school. My computer loads up just fine without the Linksys card installed. When I install the card itself I get an error message that tells me that there is an IRQ error for SB16 Emulation. Correct me if I'm wrong, but to the best of my knowledge this means that they are both trying to use the same IRQ upon startup.
To try and fix this, I freed up a couple of IRQ spots to see if either one of the two would move over to the free places. No dice... Then, I tried to change their IRQs manually. Again, no dice... Since then I have installed other cards (DVD decoder and TV tuner) and they each used the free IRQs without a hitch.
Why won't the Linksys card or the SB16 Emlationdo the same thing and switch to a free IRQ instead of conflicting? Any help would be appreciated...
Thanks in advance,
Eric
Thanks in advance,
Eric
