IRQ Problems... please help.
beatmix01
1,008
ok here is my problem.... i have 8 devices sharing one IRQ...
i am running an abit kt7-raid motherboard
IRQ 11 Microsoft ACPI-Compliant System OK
IRQ 11 NVIDIA GeForce4 Ti 4400 OK
IRQ 11 VIA Rev 5 or later USB Universal Host Controller OK
IRQ 11 Linksys LNE100TX Fast Ethernet Adapter(LNE100TX v4) OK
IRQ 11 VIA OHCI Compliant IEEE 1394 Host Controller OK
IRQ 11 Creative AudioPCI (ES1370), SB PCI 64/128 (WDM) OK
IRQ 11 HPT370 UDMA/ATA100 RAID Controller OK
any idea's?
thanks people.
bond007taz
547
by the way the IRQ is set up, I would assume you are running windows XP? There is no way you can change this unless you reinstall XP and change the, dam I forget what you need to change during the install, but right now windows is controlling the way it wants to control your hardware. If you are serious about controlling the IRQ's yourself, like in windows98, check out the groups at deja.com or look under the knowledge base on microsoft.com
beatmix01
1,008
problem is that my audio is constantly skipping every time i check my email in outlook
pyrojunkie
243
I don't think that is caused by the IRQs be shared. That sounds more like a lack of memory issue. How much RAM do you have? What are system resources at when you startup?
