According to windows and Sandra my Geforce 2,(both)USB and SB Live are useing IRQ 11. This shouldnt be right should it? Everything seems to run ok I guess. How do I fix this if it needs to be?
you using win2K? It's the OS using ACPI. It allocates the IRQs to the components. If it's running ok, then it's not a problem. If you have problems, do a search on ACPI in the forums, and you'll find a whole mess of threads.
