irq problem
Taylorm
I just installed windows 2000 and i went in msinfo32 and ehcked out hardware resources/conflict sharing and it had:
Resource Device
IRQ 11 NVIDIA GeForce DDR
IRQ 11 VIA USB Universal Host Controller
IRQ 11 Linksys LNE100TX Fast Ethernet Adapter(LNE100TX v4)
IRQ 11 Creative SB Live! series(WDM)
IRQ 11 HPT370 UDMA/ATA100 RAID Controller
My comp has locked up a few times running games im thinking that these irqs caused it.
What can i do to fix this?
Delete all of your IRQ settings then reboot and let Win2k do it job. If you still have problem, then remove the conflicting devices, and phycicaly install each device & reboots till all devices & drivers are setup.
Win2K, when using ACPI will set up such a IRQ configuration (sharing one IRQ). You can change this back to setting the computer to being a standard Pc rather than an ACPI compatible. Though are some downsides to doing so, though I can't remember off the top of my head, but I have numerous devices sharing IRQ 9 and all my devices work well, so you may have to look beyond the sharing of IRQs.
--Mark
