IRQ CONFLICT NEED HELP
lillazy23
Banned
Feb 16, 2001
149
hey guys need help fixing this problem. 00 system timer
01 standard 101/102 microsoft natural keyboard
02 programmable interrupt controller
03 communications port (com2)
04 communications port (com1)
05 Creative SB Live! Series
05 ACPI IRQ holder for PCI IRQ steering
06 standard floppy disk controller
07 ecp printer port (lpt1)
08 system cmos/real time clock
09 kingston etherx pci 10/100 fast ethernet adapter
09 via tech 3038 pci to USB universal host controller
09 acpi irq holder for pci irq steering
09 sci irq used by acpi bus
10 win95-98 promise ultra100 ide controller
10 acpi irq holder for pci irq steering
11 nvidia geforce2 gts/geforce2 pro
11 acpi irq holder for pci irq steering
12 standard ps/2 port mouse
13 numeric data processor
14 via bus master pci ide controller
14 primary ide controller (dual fifo)
15 via bus master pci ide controller
15 secondary ide controller (dual fifo)
the problem is with the Kingston NIC card and my USB controllers. They are both using the same IRQ. And I cant change them for some reason, I have tried changing NIC IRQ to 4 but the USB controllers move with it. I have tried changing slots for the NIC card but still nothing. Theres nothing in the A7V133 bios that lets me change the USB controller's IRQ. Anybody know how I could fix this problem??
AMD 1.2
A7V133 bios 1004
via 4.29v driver
jrwicker
4
I have an ASUS A7V and had many irq problems(drove me crazy). Anyway this guy at work who used to be comp tech. told me to remove all cards from device manager and remove them physically. Then install one card at a time. After each install shutdown comp. and install next card. Time consuming but it worked. Don't know if that will help or not.
piercedan
29
Can you remove the NIC, reserve IRQ 4 in the BIOS, boot the OS, and then power down. Next insert the NIC and boot. Change the NIC IRQ to 4.
Let me know if this helps!
The Box
Rhonda85
230
I have heard that PCI devices can use the same IRQ with no problems. My PC has a similar situation. Did you check device manager to see if you have any conficts? My USB uses the same IRQ as my WinTV pci card & the both work fine & windows reports no conflicts.
Rhonda
