Its C, and I guess the real IQ test is to see if you can figure out that you can just go back through it and answer that one question until you figure it out
<< xirtam, eh? Your username is 'matrix' spelled in reverse. Similarly, this puzzle must be approached in a backasswards way in order to solve it.
Here is the wording of the problem:
Below are four triangles that have letters arranged in a certain order to spell out a sentence related to that order. Determine the pattern and fill in the last letter.
The sentence, as Turin39789 noted, is GO BACK TO THE START. The answer is the letter T, which is item c.
You begin with the last triangle (the one in the lower right) with GOBA, then proceeding to CKTO, THES, finally TAR?)
The pattern for each triangle is:
1 - letter at apex
2 - letter within triangle
3 - letter at left base
4 - letter at right base >>
Good god in heaven, Osma, how did you do that & still stay in the 15 min limit for the test?
Argh, I feel like a big dummy. But of course the test still says I am Mensa material.
Maybe part of the intelligence test is to know that it's all B-S!
<< Heh.. I just read the title of this thread, and started laughing uncontrollably for some reason...
(well, actually, I sort of chuckled and smiled wanly, but, well, what can you do...?) >>
Here is the wording of the problem: Below are four triangles that have letters arranged in a certain order to spell out a sentence related to that order. Determine the pattern and fill in the last letter.
1 - letter at apex
