Has anyone gotten the VPN functionality going on a Webramp 700s box? I have it unlocked and available for configuration, but I would like to be able to use an XP built-in connection to get inside (i.e., no third party clients)...
Now, normally XP only supports PPTP, BUT I have done some digging and determined that you can actually turn on IPSec functionality from XP's MMC (apparently not many people realize this). The question is, I'm not sure exactly what I should be choosing. And does it matter if my 700s is using DHCP to get its address from Comcast since the clients will all be using DHCP as well?
So really I need config advice on both ends, serverside and clientside. A little info on the current config: The Webramp had VPN enabled, with NetBIOS broadcasts enabled as well. The VPN gateway is set as my Comcast DHCP address. A unique firewall identifier is specified, and it matches the name since I believe this has to be b/c I have a DHCP address (I could be incorrect in this assumption). MD5 Authentication is set (no encryption). I chose IKE, and A shared secret has been established. The network to connect to is 192.168.1.0 (my NAT range), 255.255.255.0 mask. On the xp client side, IPSec snap-in has been added using MMC. Under the "Security" tab for the connection, advanced settings have been chosen, with 'MD5 challenge' selected and 'no encryption allowed' chosen to facilitate MD5. The shared secret has been entered into the client side as well.
Am I on the right track at all? I'm still a security noob--apparently my intermediate knowledge of Sun/Solaris in networked environments isnt translating too well into secure networked environments
 I figure my issues are generic to IPSec/VPN, but if you've done this on a Webramp that would be great since you could let me know exactly what screen my problems are on
Thanks to anyone who can shed some light on this for me!!
