iPod Battery Replacement
Funyuns101
GF just got a new nano and has this other one lying around. The battery has really diminished over the years, but it works fine aside from that and a few scratches here and there from normal wear & tear.
Anyway, has anybody replaced their own?
I was looking at this site: ipods99
I'm an iRiver user, so I don't really know much about ipods.
any thoughts?
any thoughts?
If your talking about the 3rd ipod non nano
iv replaced my sisters in about 5 mins
its not hard you might just add a scratch to it though if your not care full
i did buy my battery from ebay for cheaper though
Yes, the non-nano iPod "classic" if you will.
any chance you remember the seller?
I'm trying to find a somewhat reputable place to buy the battery that's essentially guaranteed to work well for awhile.
http://cgi.ebay.com/FOR-3G-IPO...rksidZp1713.m153.l1262
I replaced the battery in my first-gen 10GB iPod, using a kit from NewerTech. It was a bitch getting the thing open, but using the provided tools I was able to do it without damage, and once the case was open the battery replacement itself was a breeze. No idea about a nano, though.
thanks alfa, the battery has been working well in your sister's iPod?
yup no problem
It has a longer battery life then when she got it!
its been 7 months and its fine so if it dies in 5 months ill have no problem replacing it ($10) big woop
good luck 😉
