iPhone: get the GSM signal in numbers WITHOUT jailbreaking? Is it possible?
starriol
187
Hi guys,
I need to measure the signal rate in different parts of a building. I know that it can be done with SBSettings, but I don't want to jailbreak my phone.
Can this configuration (getting the signal strength in numbers instead of the lines) be done without jailbreaking?
pm
Elite Member Mobile Devices
Jan 25, 2000
7,419
22
Bring up the dial menu and dial:
*3001#12345#*
this brings up field test mode and converts the signal strength in the upper left to a number. It's in dB and more positive/higher numbers are better. So -60 is much better than -90.
For what you are trying to do, you might find the value for the field "Serving Rx Level" to be more useful - it's is under the Field Test menu under GSM Cell Environment -> GSM RR Info. Higher numbers are better here as well. It's more useful than the dB number in the upper left because it updates a lot more often - and you can manually update it by hitting the refresh button.
pm
Jan 25, 2000
7,419
22
For WiFi: use Netstumbler (Cydia, free) or Wififofum (app store, $3). There's a nifty graphical demo of WiFiFoFum here: http://www.aspecto-software.com/wififofum/
The field test does it for GSM/EDGE and 3G - the 3G signal info is under "UMTS Cell Environment -> UMTS RR Info -> Serving Rx Level" and the EDGE/GSM info is under "GSM Cell Enviroment -> GSM RR Info -> Serving Rx Level". If you aren't in 3G then the 3G section is blank.
