So I recently purchased a "Used Like New" iphone from the amazon warehouse, and when I received it, it looked like it had never been opened.
So I backed up my iphone 4s and then loaded everything onto the "new" 5. I added the phone's macid to my home router's list so it could see the wifi broadcast. When I tried to type in my password it took several attempts (~10) to connect to the router, and I thought I was good to go. Unfortunately, the phone constantly drops wifi connection, and when it does connect, it is balls-to-wall slow before dropping out and relying on my cellular data connection which I've had to turn off to prevent going over my monthly limit. This is all while sitting next to my laptop and 4s that were holding the connection rock solid.
I tried resetting all network connections, but to no avail. I've tried resetting the phone entirely without loading a backup of my previous phone onto it. If anything, it is worse. The phone sees the wifi broadcast but simply refuses to connect. I've had the exact same experience on the "work" network. Both are on WPA, which I've read could cause a problem, but I don't see setting the network to open or even WEP as an acceptable option.
So I brought the phone into the apple store (of course their unsecured wifi worked fine) and told them what I've gone through and they ran some silly diagnostic on my phone and found nothing wrong. It looked like they were about to switch out my phone until they saw it was no longer under warranty. It was sold in October 2012 and manufactured in June 2013 (wtf?).
I've also tried doing some silly things I've read on the internet like setting dns server 8.8.8.8, setting http proxy to auto, and taking off the case (rubber) but none of these had any effect.
Obviously I'm going to return it to Amazon, but has anyone run into this problem with their 5 been able to find a solution?
