iPad Pro Case - 9.7 Inch Ultra Slim Leather Case Smart Cover with Magnetic Auto Sleep Wake-up Function $6.99 (was $13.99)
[FONT="][FONT="]FREE Shipping with Prime or on orders over $49.[/FONT][/FONT]
[FONT="][FONT="]$7 off code: 736H45DU
[/FONT]
Black:[/FONT][FONT="]https://www.amazon.com/dp/B01DY04AI0
Blue: https://www.amazon.com/dp/B01DZASB98
[/FONT]
Product Description
9.7 Inch iPad Pro Case Cover
Protect your beloved iPad Pro anywhere and anytime!
Effective and Elegant Full Protection
Folding PU leather shell and microfiber lining material provide full protection for the whole iPad body. While protecting your iPad from scratch and scuff, it also adds negligible thickness and weight to the device.
Embedded Magnetic Enclosure
The inbuilt magnetic attachment in the right-most segment of the cover is strong enough to snap in place, and it stays closed in your crowded backpack or handbag on the go.
Auto Wake-up and Sleep
By passing the lock screen, when magnets on the right edge locking the cover, the iPad automatically goes to sleep and saves battery life meanwhile. Slightly peel back the cover, and the iPad magically wakes up.
Roll-up Stand
The smart cover employs three foldable creases at which it can fold into a stand. Roll it up into a little triangle shape and it allows you to prop the iPad at a low incline for typing, and at a steep angle for reading and viewing, without sacrificing stability.
Compatibility
Specially made to fit iPad Pro 9.7 inch. Lose yourself with the hand-free reading.
[/FONT]
[/FONT]
Product Description
Roll-up Stand
Compatibility
