iPad Mini - Needs a damn retina display
Discussion in 'Mobile Devices & Gadgets' started by badb0y, Nov 2, 2012.
  1. Capt Caveman
    Capt Caveman Lifer
    Jan 30, 2005
    33,520
    134
    [​IMG]
  2. NikolaeVarius
    Oct 25, 2006
    11,036
    Oh. My. God. A larger screen can show more stuff? STOP THE PRESSES. That extra .85 inches was the PERFECT AMOUNT to increase the size of the screen by. Apple has shown to be perfect once again.
  3. Phokus
    Phokus Lifer
    Nov 20, 1999
    22,189
    25
    It's not only the size, but also the fact that the ipad mini has a 4:3 aspect ratio while the nexus 7 has a 16:9 or 16:10 (forgot which).
    Obviously, if you're going to read a webpage in landscape, you'll see more with 4:3.
    What Tim doesn't tell you, is that the Nexus 7 is MUCH better at TV, Movies, Youtube because that's how they do their aspect ratios.
    The solution to this, of course, is to view websites in portrait mode.
  4. DLeRium
    DLeRium Lifer
    Feb 19, 2001
    20,114
    which looks awkward too in 16:9. How many of you surf on your widescreen monitors in vertical? I understand putting 3 monitors together to take advantage of AMD's Eyefinity, but yes monitor in vertical = fail for reading.
    Even in vertical, it's more appealing to have 4:3. Why did everyone tout 16:9 or 16:10 anyway? Becauuse you can split the damn screen in half. What does that give you? 8:10, or 8:9. More squareish.
    I think more people use their tablets for casual reading surfing than videos, so to make it only for videos is fail. You can still watch 16:9 content on a 4:3 tablet.
  5. MrX8503
    MrX8503 Diamond Member
    Oct 23, 2005
    4,531
    The rumors of Steve jobs and Ive spending months settling on the right size/aspect ratio for the iPad seem truer everyday.
    People watch vids on their tablets, but that's not the majority. So....16:9 is not optimal. 16:10 is better but I prefer the iPad aspect ratio.
    Something to note, android tabs lose a lot of space from the footer software keys. It's a thick bar for 3 buttons.
    #80 MrX8503, Nov 5, 2012
  6. ponyo
    ponyo Lifer
    Feb 14, 2002
    13,756
    128
    Yeah 3.5" screen phone and 10" tablet are the perfect size. I guess that's why Apple made 4" screen iPhone 5 and 7.9" iPad Mini. Apple was tired being right and wanted to make some imperfect products too.
  7. Aikouka
    Aikouka Lifer
    Nov 27, 2001
    27,469
    33
    Why is that? Because it closely matches the 16:9 aspect ratio? If you were talking about the iPad 4 vs. Nexus 10, you would be more accurate, but unfortunately, Mini vs. Nexus 7 isn't so cut and dry. The larger screen on the 4:3 Mini actually gives it a larger viewing area when viewing 16:9 content compared to the Nexus 7's 16:10 screen.
    Unfortunately, no one ever seems to post the flippin' screen dimensions anywhere as everyone is all about diagonal sizes. So, I did a little math, and got the following dimensions:
    iPad Mini:
    6.28
    4.71
    Nexus 7:
    5.92
    3.70
    Fortunately, Apple provides the overall surface area in inches squared of a 7" tablet and their own tablet, which made this much easier. All you do is solve the following equation for n:
    [aspect ratio: width]n * [aspect ratio: height]n = [surface area]
    Then you multiply by the respective aspect ratio number again to get the actual screen size.
    Now, what we're looking for is actual viewing size in inches. Both of them will use the entire height (i.e. 6.28 and 5.92); however, neither of them will use the entire width, because the Mini is 4:3 (will use 75%) and the N7 is 16:10 (will use 90%). Because of that, the iPad Mini actually uses 3.53" to display the video and the N7 uses 3.33".
    So, the effective 16:9 content display size is...
    iPad Mini = 6.28" x 3.53"
    Nexus 7 = 5.92" x 3.32"
    As long as you're willing to deal with the fact that you're wasting more screen real estate on the iPad Mini playing 16:9 content, you're still getting a bigger viewing area as an end result.
  8. brian0831
    brian0831 Junior Member
    Nov 2, 2012
    19
    you are getting a bigger viewing area, but if you're watching an HD movie e.g. 720p, aren't you also losing quality due to the iPad mini having to downscale to fit the width of 1024 pixels, whereas the nexus 7 or kindle fire can play it with full quality?
    I can see that a 4:3 resolution is better for web surfing and general content consumption, hence why the 4:3 aspect ratio for the iPad mini is better suited most of the time than a nexus 7. I can also see the reverse logic to be true for kindle fire vs. iPad mini, since Amazon's strength is selling streaming movies and media, which is better consumed on a 16:10 device, as well as ebooks, which are likely to be read while holding the device vertically
  9. TuxDave
    TuxDave Lifer
    Oct 8, 2002
    10,577
    You could argue that but that wouldn't have to do anything with the aspect ratio which only plays a factor in viewing size. The simple point is that the iPad mini is further away from 16:9 but ALSO has a longer diagonal and that overcomes the wasted space.
  10. Aikouka
    Aikouka Lifer
    Nov 27, 2001
    27,469
    33
    Yep. That's true as well.
    I think it was Amazon that had something that said something along the lines of "the iPad Mini doesn't play hi-def videos." I understand what the statement means, but it felt a little disingenuous to me as it makes me wonder if technologically illiterate folks will think that the iPad Mini is not capable of handling a video that is 1280x720. Although, to be fair... I think iOS will refuse to play that video from the Video app as it isn't a supported resolution. That doesn't mean the iPad Mini's hardware cannot handle it though.
  11. badb0y
    badb0y Diamond Member
    Feb 22, 2010
    3,946
    10
    Did you just post this? Please, I'll give you some time to edit it because it seems awfully hypocritical considering the difference in screen size between 4 inches and 4.8 inches is smaller than the difference between 7 inches and 7.85 inches. Aren't you the same people salivating over the GSII screen and the GSIII screens because how big they were? Wasn't bigger better? Or was it bigger is better when Apple doesn't do it?
  12. MrX8503
    Oct 23, 2005
    4,531
    The rumor was for tablets. Also the mini and iPad shows the same amount of content.
    If you look at the majority of tablets out there, the screen is not optimal for its use.
  13. Tsavo
    Tsavo Platinum Member
    Sep 29, 2009
    2,618
    Where did Apple find a 16:5 aspect ratio screen, as seen on the left?
  14. TheStu
    TheStu Moderator<br>Mobile Devices & Gadgets
    Moderator
    Sep 15, 2004
    11,850
    9
    They lopped off the always(?) present software buttons. Because always present software buttons that add no more functionality than hardware buttons are stupid.
    They also don't show the status bar on the iPad screen shot. Not sure about the status bar on Android, is it there all the time?
  15. Zink
    Zink Senior member
    Sep 24, 2009
    209
    That is just the size of the browser window. On Android there is a notification bar at the top, chrome tabs and search, and soft buttons at the bottom. On the iPad there is a notifaction bar at the top and safari navigation and tabs.
    [​IMG]
    [​IMG]
    [​IMG]
  16. ponyo
    ponyo Lifer
    Feb 14, 2002
    13,756
    128
    So now the rumor was only for the tablet. Reality distortion field in full effect.
    Screen on Nexus 7 is not optimal for its use? I only use landscape for games, videos, and pictures. Rest of the time it's in portrait view held with one hand. Pretty much exactly like how you use your 16:9 iPhone 5... Oh wait, I see the point you're trying to make now. You're unhappy with your iPhone 5 screen as it's not optimal for its use.
  17. Aikouka
    Aikouka Lifer
    Nov 27, 2001
    27,469
    33
    My iPad is locked in landscape mode and stays there... so I'm not sure why you suggest that I ever use it in portrait mode unless a game requires that I use it. :p
  18. Dari
    Dari Lifer
    Oct 25, 2002
    17,069
    4
    This 7 inch device has the same resolution as the current iPad.
  19. MrX8503
    Oct 23, 2005
    4,531
    Look at the screenshots above you.
  20. jpeyton
    jpeyton Moderator <BR> SFF, Notebooks, Pre-Built/Barebones
    Moderator
    Aug 23, 2003
    25,244
  21. badb0y
    Feb 22, 2010
    3,946
    10
  22. mosco
    mosco Senior member
    Sep 24, 2002
    940
    I agree with the title of this thread, we just got a couple iPad mini's at work to develop with, and my only complaint is the screen.
    I have been using a kindle Fire HD for the last week, and the iPad mini wins in all hardware aspects except for the screen (and maybe the speakers, the kindle fire has pretty good speakers and I haven't tested the iPad mini too much yet with loud music). If the iPad mini had a retina screen, I would buy one with LTE right now. The hardware on this thing is insane. It's thin and amazingly light. I love the thin bezel too.
    #97 mosco, Nov 6, 2012
  23. dagamer34
    dagamer34 Platinum Member
    Aug 15, 2005
    2,592
    iPad mini + Retina Display = no one buying the larger iPad.
  24. mosco
    mosco Senior member
    Sep 24, 2002
    940
    The "new iPad"/"new iPad.5" is pretty beefy. I wouldn't surprised if the next iPad gets thinner and lighter, at which time the iPad mini would gain a retina screen.
  25. jpeyton
    Moderator
    Aug 23, 2003
    25,244
    Exactly as I predicted when the iPad Mini was announced:
    Poor quality screen, frame too wide for comfortable one-handed use.
    Gizmodo tears into the screen even more:
    http://gizmodo.com/5959068/a-week-with-the-ipad-mini
    #100 jpeyton, Nov 10, 2012
