IP35-E not keeping settings
man00
Just got it running today, seems to be ok for the most part. I have noticed if I up the FSB to 400 and reboot all seems to go fine. Until I shutdown then I see its running stock again but in bios still shows 400mhz, I enter the 400mhz again and its running 3200mhz. Until the next shutdown (power off). I'm using Corsair
TWIN2X2048-6400 memory (setup 1.90v) The CPU is E6750, default voltage.
Everything I tested shows the ram volts at 1.87, any idea how to keep the FSB settings in Bios (ver 15)
thanks
Its interesting how another manufacturer's board, a gigabyte ds3l, that I had this week had the exact same problem. Its latest bios doesn't solve it tho so I returned the board.
From one of my posts in that thread quoting Hokiealumnus:
Originally posted by: MadScientist
Hokie,
From your Abit forum post:
"Additionally, the FSB reset issue when you remove power that presented itself with v.14 is still present in v.15. Shutting down & powering back on fixes it (restarting doesn't), but annoying nonetheless."
You have a couple of choices: don't completely power down, keep your MB on standby power and stick with bios v15; or flash your bios back to v12.
