I had been runing an IP35-E system happily for a couple months. The only problem to arise is that a few times I had to clear the CMOS in order to boot the system because I was receiving no signal to my monitor, though my entire system seemed to turn on (but not booting into windows). I have read that others have had this problem - the "cold boot," but mine was fixable with clearing the CMOS or simply turning off the power to to the power supply and then trying again.
Ever since a month or so ago, I've had major problems. I have received the no signal to my monitor upon booting, its just not posting. The video card fan is on, all the fans are on, both the red and green LED work on the mobo, but i get no signal.
I tried everything. I removed everything but one stick of RAM, mobo, processor and heatsink, and video card (I still kept it in the case). I swapped my RAM through each DIMM slot. I did a deep reset and countless CCMOS. Finally, just by random luck, I got the thing to boot into BIOS and was able to change my Vdimm back to 2.2 and everything worked again.
Fast forward a month.
While I was gone for the weekend, my wife tried to get on the computer and was unable due to a BSOD that must have occurred while the computer was idle. She turned it off and then back on and went to the same BSOD. Then she turned it off and gave up. Now when I have tried to boot it, I am getting the same issue as before - everything is turning on in the pc (green light on mobo included), but its not posting. I've cleared the CMOS, done a deep reset, moved the RAM around to each slot - none of its working.
Looks like my ip35-e is junk. Any ideas?
System Specs:
IP35-E
Corsair 550 VX PSU (I've read bad things about combining the ip35-e and corsair PSUs)
E2180 (OCed to 3.2 at 1.4v)
2 GB Crucial Ballistix PC6400
EVGA 8800GT
250 GB Seagate Barracuda
Xtreme Gamer Sound Card
System Specs:
IP35-E
EVGA 8800GT
