I am going to build a new system inside Antec Sonata III case. I have collected many good opinions about IP35-E so I will get this one as I don't care about RAID, two network cards or 1394.
I'm planning to get one of the cheapest C2D (maybe even 2140) and then upgrade to 45nm in about 6 months or so. I will overclock it of course
I have not decided yet which cooler to choose. Generally I think the best setup of CPU cooler is to mount it in such a way that hot air from the cooler flows directly into case's rear fan. This way airflow is undisturbed and as straight as possible from the front of case through the cooler and directly into rear exhaust. Do you think it makes sense to put it that way?
Could you also recommend cooler that can be mounted this way? I prefer silence to performance...
Thanks!!
Thanks!!
