My college is soon to run out of public IP's and they need to start to run NAT. The IT department is trying to figure out how to implement a system that will allow them to hand out both Public and Privite IP's via a DHCP server. I know that this can be down and so does the IT department, "THE CATCH" but they want to go a step farther and set certian MAC addresses to get Public IP's and the rest will get Privite IP's. Also as soon as the addation and remodeling of the campus is 100% complete and all departments stop moving across the building they are going to start to use vLAN's. They currenly can't use vLAN's because they don't have enough IP's to divide up amoung all the vLAN's they would have. The hardest part of this is that they don't want to use Static IP's becuase of the number of systems on campus (400+ at any given time, laptops come and go) and they currently don't have NAT running. The IT department also would like to have a web front end for this setup, so that the IT manager and their workstudies can make changes to the system on an as needed basis. The web front end would be used to add MAC addresses to the config file on what ever DHCP server they end up using.
First question can all this be done or not?
Second question what is the best way of setting this up if it can be done?
From rest of world --->| Cisco 3640 | -------> Linux Router/NAT Box/DHCP server ---> vLAN1 ----------------- |
|---> vLAN2
|---> vLAN3 & so on
|---> vLAN2
|---> vLAN3 & so on
