iOS 5.1.1 battery life issue?
Pheran
5,740
35
It seems like the battery life on my iPhone 4S has gotten significantly worse since the iOS 5.1.1 update. I used to be able to standby for up to 3 days, but now the battery is draining in one. I've seen a few other reports of this, anyone else experiencing it? I may have to see if I can figure out how to downgrade to 5.1.0 to do a better comparison.
Tyranicus
914
My iPhone 4 appears to have about the same battery performance on 5.1.1 as it did on 5.1.0.
TuxDave
10,571
Mine works just the same as before. Usually 2 days of reasonable use before I need to plug it in.
squall1212
8
How about if you get back to 5.1.0,get to know some one suffers a same and then get recover as he come back to 5.1.0...
phillyTIM
1,942
10
If this is any guage: I fully charged my iPhone 4S (iOS 5.1.1) before bed last night; 8 hours later it was at 98% charge left. That's with the Siri "raise to speak" option turned OFF.
Pretty darn good batter life guage, if you ask me. Many people in the past typically have complained about a huge overnight drain.
Qbah
3,754
10
Connected to a WiFi? Push email enabled mixed with regular email periodic checks?
OP - try a reset all settings. No application will be touched. My 4S on 5.1.1 lasts 2 days easily. At 55% now and I took it off the charger yesterday in the morning (30 hours ago).
