- Apr 14, 2005
- 362
- 0
- 71
I decided to remove iOBit 360 after reading that they have 'hijacked' code from Malwarebytes. I had installed v1.20. I used the Add/Remove in control panel of my XP-Pro. It removed from the list; but when checking the Program Files folder; it still exists. Unable to delete the iObit folder. It comes back with the error message "is360mon.dll" is in use. Opened the iObit folder and found "is360mon.dll", and tried to remove it. Still not able. I used 'search' to see where the .dll would reside. I GOT EVERY FOLDER & FILE & Picture on my PC returned in the search !!! Does that mean there is a "is360mon.dll" in all my files ?? I can't even get IE to get online anymore on that PC; get a 'program not responding' message. RegCleaner found iOBit and removed it from that list, but the folder in Program files still exits.
Any Suggestions ... I guess as a last resort .. I can wipe the drive and reload XP ! But I really don't want to !
