I have a Lian-li v1000 which means an inverted motherboard. I recently installed a A8N32 SLI Deluxe ASUS motherboard which has a heatpipe. My idle MB temperatures is typically 46C. This is a little high and I am guessing it is due to the inverted heat pipe. Has anyone looked into this issue? What is the best (most effective) solution? Should I install a Northbridge cooler or ultimately think about a "right side up" case?
