Invalid system disk/no fixed drive
kiehn
30
kiehn
03/29/2003 10:26 PM (NEW!)
We've had numberous problems with our system freezing, restarting, constantly restoring the registry, etc. Now when I start it I get the blue HP screen and following a message stating invalid system disk. So I booted up with the boot up disk and decided to fdisk, format and reinstall. When it was
finished nothing happened. I tried booting up again to check the C dir and it told me it didn't exist. So I restarted and the same message invalid system disk. I unplugged the hard drive and again got the same message, invalid system disk. Would I be correct to assume the hard drive is bad???
Thanks kiehn
Reply Quote Top Bottom Edit
mechBgon
03/29/2003 10:30 PM (NEW!)
That could be, or maybe Windows is just having a bad day. Do you have a standard Windows disc, or a HP-specific restoration disc? Also, what version of Windows (98/2000/XP)?
Team AnandTech Distributed Computing... get into it.
Edited: 03/29/2003 at 10:31 PM by mechBgon
spankyOO7
03/29/2003 10:34 PM (NEW!)
u successfully reinstalled windows and upon reboot, u get the invalid system disk error messege?
btw, is c: your active partition?
My Rig n Refs
Spanky: u o/c'ing?
Pillage: yes
Spanky: mhz ho
Pillage: it's GHZ bitchhh
PliotronX: I'd like to see the 3DMarks on a 486
GnomeCop: actually I think 3dmark just displays a giant middle finger if you try to run it on a 486
Edited: 03/29/2003 at 10:37 PM by spankyOO7
kiehn
03/29/2003 11:39 PM (NEW!)
First I should say the OS is win98se HP edition. When I reinstalled the HP CD I watched all
the files spinning down the screen as they usually have in the past, but this time it did not
say please remove cd and reboot, there was no repsonse at all and I tried it twice. As far
as the invalid system disk error message I'm not sure I saw it before I tried to reinstall but I do
remember I wasn't getting anything more than the blue HP insignia screen when the computer was turned on so thats why I formated and tried to reinstall. When I did boot with the startup disk
and checked the c: dir, I believe it say there were no fixed drives available. I really hope it is the hard drive because Ive already ordered one. Current hard drive: Quantum fireball CR 6.4, 3.5, Inerface ata/4. ultra ata/66 I ordered a used Quantum fireball 10.2, EIDE, 3.5 series, so I hope it fits and I'll be able to reinstall the OS without any problems.
Thanks again, kiehn
tjaisv
Banned
Oct 7, 2002
1,934
Yeah it sounds like it might be a bad disk. The only way to know for sure would be to install it in another computer (or install another in yours) and see if the same problems occur. Either way you'll know whether it's the disk or something else.
