First time poster, here.
I'm preparing a brief report for my IT department on the differences in power consumption between several different hardware configurations. I'm using a Kill A Watt meter while running Prime95's small FFT stress test to measure power consumption under load.
I figured I'd track temperatures as well since I was running stress tests on various systems. It's not pertinent to the final report, but it wouldn't hurt to have the information. My problem is that I am having trouble interpreting the readouts for the FX 8350 configuration. If it helps, the board is a Gigabyte GA-78LMT-USB3.
CPUID Hardware Monitor was not providing data that I could easily interpret so I decided to run Speedfan and Hardware Info as well. I've done some Google Fu to help understand these figures, but I can only find mixed and often conflicting information. In reference to the attached screenshot, my conclusion is that the CPU IHS temperature is 52 degrees while the socket temperature is 58 degrees. To me, this relationship seems reversed from what I've seen with Intel systems. Additionally, Speedfan and Hardware Monitor report TMPIN02 as 67 degrees. If this is the North Bridge, it seems odd that it would be warmer than the CPU and socket.
This is an office environment so I'm running everything stock.
Can anyone shed some light on these figures for me? I'd greatly appreciate it.
