internet speed megabits/megabytes
sonoma1993
How come broband internet company promote there internet speed in megabits instead of megabytes of kilobytes? Im assuming it an advertisement stratgey.
No it's not an advertisement strategy. Bits is used in terms of transfer speed, bytes is used in terms of size (usually)
Pretty much. When Adelphia says you have a 6mbps connection, that's bits, not bytes. Divide by 8, and you have roughly 750KB/sec, in bytes. I didn't know any ISPs were using bytes to promote their speeds, that's just stupid.
did you know that the hard drive manufacturers measure gigabytes with a metric measurement? 😉
Network transfer rates are a serial connection, so it ?bps. If it's a parallel connection, then it would be ?Bps.
🙁 Gimmie a 8mbps connection =)
Originally posted by: TheToOTaLL
8 bytes in 1 bit - the math's not that hard.
apparently it is! :evil:
As someone else has already mentioned; transmission speeds are measured in bits per second (b/s) and storage capacity and storage rates are measured in bytes (B) and bytes per second (B/s).
marketing. a bigger number is sexier. most consumers don't know the difference between a bit and byte and just confuse the two. so the number was more important. and yes, the modem figures got insane. 56000 kbps omg its huge speed!
wouldnt that be "56000 bps"... not kbps
oops. yes but they are using bits instead of bytes is the point.
