Internet problem ......HELP!!!!!
gipson73
9
Ok Hello there and thanks for looking at this post. Hopefully you can help.
Here it goes, my friend has a k7s5a motherboard that has a built-in lan device. I have tons of problems getting to web pages (have att broadbang high speed) I can try to get on MSN.com and it will not load. Try agian and will not load. Try for the forth time and wham it loads fast. I can not get to ameritrade.com,hp.com and all sorts of other web pages. I lowered my security settings and let in all cookies but it does not do a thing. I can get onto microsoft.com slow but download file at fast speeds. It seems that I can download files fast but I can not get to web pages. I called ATT and they suggested I get the 128BIT encyrption patch. Didn't work either. Anyone have a suggestion. Win98se was just clean installed last night to see if that was the problem. I am sure that the Network stack it set up correctly. Oh ya I put my LAN card in also(IntelPRO 10/100) and that didn't help either. Could it be the MOBO? I can't beleive it is a hardware problem. I would think it is in software or internet setting!!!
gipson73
9
I tried that. I wish it were that easy!
I got the new drivers for the MOBO and the sis900 drivers for the LAN card too
another thing I tried was to more the DDR RAM to a differnt slot and I also tried some SDRAM. Just to see if there was a RAM problem.
Sid59
11,879
obtain a different NIC and see if that works. also try another browser, Mozilla ..
