Internet problem ......HELP!!!!!
gipson73
9
Ok Hello there and thanks for looking at this post. Hopefully you can help.
Here it goes, my friend has a k7s5a motherboard that has a built-in lan device. I have tons of problems getting to web pages (have att broadbang high speed) I can try to get on MSN.com and it will not load. Try agian and will not load. Try for the forth time and wham it loads fast. I can not get to ameritrade.com,hp.com and all sorts of other web pages. I lowered my security settings and let in all cookies but it does not do a thing. I can get onto microsoft.com slow but download file at fast speeds. It seems that I can download files fast but I can not get to web pages. I called ATT and they suggested I get the 128BIT encyrption patch. Didn't work either. Anyone have a suggestion. Win98se was just clean installed last night to see if that was the problem. I am sure that the Network stack it set up correctly. Oh ya I put my LAN card in also(IntelPRO 10/100) and that didn't help either. Could it be the MOBO? I can't beleive it is a hardware problem. I would think it is in software or internet setting!!!
JackMDS
29,540
419
It is probably will be helpful if you tell us How and What is connecting you to the Internet?
JackMDS
29,540
419
Download DrTCP: <a target=new class=ftalternatingbarlinklarge href="http://www.dslre
ports.com/front/DRTCP021.exe">http://www.dslreports.com/front/DRTCP021.exe</a>
Run the proggie, it will show the current settings of TCP/IP parameters. Write them down.
You can change any variable that you want, click Apply, and reboot the computer, if no good; you can always change to your original values.
Start with:
MaxMTU - 1500
Tcp Receive - 255552
Window Scaling - Yes
Time Stamping - No
Selective Acks - Yes
Path MTU Discovery - Yes.
Black Hole - NO
Max Duplicate - 2
TTL - 64
Of course YMMV.
