Try choice 2 .
http://www.windows-help.net/windows98/ie50-11.shtml
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q194177
W95 you have 3 choices . With W98 , if you have IE5.1 or higher & you
still have IE4 installed the following applies . No IE4 only 2 choices .
IE5.5 if over the top of 5.1 , offers 3 choices .
You can install IE5.1 straight over 4 . A big feature with IE5 is that
it can be repaired without uninstalling . Here is how to do it . Open
Control Panel , Add / Remove , click on Microsoft Internet Explorer ,
then click on add / remove down the bottom . This opens a window with
3 choices .
Choice 1. Add , insert your IE5 install program & you can find other
items you may not have installed 1st time .
Choice 2. Repair , fixes problems that may crop up with IE5 / Outlook
Choice 3. If unfixable , removes IE5 & goes back to IE4 , now if you
want to you can reinstall IE5 or a later version or another browser
altogether .
No Microsoft Internet Explorer in Control Panel !
Start > Run , key in msinfo32 and press Enter . Click on Tools > IE Repair Tool or Start >
Programs > Accessories > System Tools > System Information . Click on Tools > IE Repair Tool .
Internet Explorer Repair tool from a command prompt:
Click Start , and then click Run .
In the Open box, type the following command, and then click OK :
rundll32 setupwbv.dll,IE5Maintenance "C:\Program Files\Internet Explorer\Setup\SETUP.EXE" /g "C:\WINDOWS\IE Uninstall Log.Txt"
NOTE : This command is case sensitive.
W2000 > Start > Run
then enter exactly (copy & paste)
rundll32.exe setupwbv.dll,IE5Maintenance
this will give you the IE Repair dialog... proceed to repair IE
Repair IE6
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q318378
http://www.3dspotlight.com/tweaks/ie6/index.shtml
http://www.winguides.com/registry/display.php/442/
