Internet Explorer help with click through links
xformer1
44
Seems like whenever I hit a click through link I get a "The page cannot be displayed" error. I am using I.E. 6 and Windows 98. For example when I go to this web site -> http://www.scoreadeal.com/coupons/office_depot.asp <- then click on the link for the coupon code, it is supposed to redirect to another page but I get the "Cannot find server" "this page cannot be displayed".
Any Ideas? This must be some security setting isn't it?
TIA,
xformer
NicColt
4,362
I did it and don't have any problems with it.
Do you still have a problem with it.
xformer1
44
yep, my problem with this still exists. It must be a problem with my browser, a freind of mine has no problem with this either. Could it be I need the JAVA plugin ?
ojai00
3,291
Sometimes those sites have codes that redirect you to a certain site. I get the same problem you get sometimes. All you have to do is remove the code that redirects and just leave the site that you're supposed to be directed to. Hope this helps.
xformer1
44
Thanks ojai, I was able to connect to the redirected site in a round about way. By holding my mouse pointer over the hyperlink and copying down the URL for the redirect and manually typing it in.
