Internet Explorer 6 Help
frostgiant
After clicking a link to a ZIP file, I accidently clicked "Open" and the checkbox for "Always remember selected action for this filetype" was selected. Now, every ZIP link always opens up and it is really annoying... I want to save them in a specific location.
How do I change this?
i'm not sure if this will work but goto options and advance and restore defaults and restart... see if that helps.
If that doesn't work, open
Windows Explorer
Select Tools / Folder Options
Click on the File Types tab
Go to the extension you want to change (zip, exe etc.)
Click on the Edit button (W2K click on the Advanced button)
Make sure the Confirm Open After Download box is checked
