Internet Connection- Weird Issue
TempletonPeck
99
I recently reformatted (read today) a computer with Windows XP.
I re-installed all the standard drivers: video, sound and network. Installed SP3, installed anti-virus + firewall.
The motherboard is a Asus P5RD2-VM. I got the network driver directly from the asus website, from the motherboard page. Realtek RTL8111b 10/100/1000M LAN Driver Version 5.652.627.2006
While the machine was already running, I plugged into the ethernet port on the back directly from the modem (broadband cable).
It made the connection, I connected to the Internet, I started downloading Windows updates after activating Windows.
Upon restart, it came back with "limited connectivity", I'd lost my connection for some reason. I tried repairing the connection, but it couldn't reaquire an IP address. It was assigning me an automatic private IP address (169.254.x.x)
I restarted the machine, same deal. Reset the modem, same deal.
Then I unplugged the network cable, restarted the machine and didn't plug the cable back in until Windows had started. It got the connection no problem, normal IP address and away I went.
Problem is, if I restart the computer, back to square one, "limited connectivity", an automatic private IP address.
Any ideas as to the problem, or what I should try?
Lemon law
20,984
You are probably missing a windows protocol or have a corrupted TCP/IP stack.
Download a winsock fix program, and rebuild your winsock. Then make sure you have TCP/IP, client for windows networks, and file and printer sharing for microsoft networks all checked and installed.
OptotsshorP
Banned
Dec 16, 2009
16
I have a wireless router and I also have a wireless laptop. I want to get my xbox connected downstairs to Live and I was wondering if I could use my wireless internet connection to connect to the router and then send a crossover cable from the laptops ethernet port to the xbox. I thought it would be easy but when I try to share my laptops internet connection it says another thing is already using auto matic ip address the router is what i think it is refering to. I dont think this is a standard setup but if anyone knows what I am talking about I would like to know if it is possible. thnaks
Pulsar
5,224
306
Optotshorp, please start your own topic in the forum, don't post to this one asking questions - that is generally considered impolite.
Dulanic
9,972
592
I know with my win 7 that the realtek drivers are bad. I have the same issue. Every time I start my PC I need to load device manager and disable and then enable the adapter and that fixes the problem. I am hoping they fix their driver soon. I am hoping fixed drivers eventually get put up on windows update. Give that a try and see if that is the same problem.
TempletonPeck
99
Thanks guys.
I took a second look and it turns out that the driver I got from the Mobo manufacturer, was actually from 2006. I only went through there because I didn't know what the card exactly was at the time.
I got the latest driver directly from Realtek and it's working like it should.
