International travel/power questions
  • Thread starter Thread starter Deleted member 4644
  • Start date Start date
D
Deleted member 4644
If a camcorder says it can use up to 240 VA does that mean it can be connected to a european powergrid without anything but a simple physical adapter?
yes. that means all you need is a simple physical adapter - something that will plug into a european socket and present you a US socket
It also has to say 50/60Hz, but if it's up to 240A, it will.
Yep, all you need is an adapter for a socket.
