Hi guys, I'm an international student and I'll be moving to the US for graduate school in August. I'm thinking about buying a new computer from scratch for when I get there, and this is what I have so far.
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=20892707
Any comments and/or suggestions and advices are welcome. Thanks!
PS: I plan on getting the I5 2400 for ~$157 at MicroCenter when I arrive.
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
A little bit of everything, little bit of gaming, entertainment (music, videos), work, web, etc
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
Trying to keep it as cheap as possible while have acceptable name brand components. Definitely trying to keep it under 1K.
3. What country YOU will be buying YOUR parts from.
I'll be in Boston, MA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
No preference, as long as it's trustworthy
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
None
6. IF YOU have searched and/or read similar threads.
Yes
7. IF YOU plan on overclocking or run the system at default speeds.
Light overclock for GPU probably.
8. What resolution YOU plan on gaming with.
I'm using 22" 1680x1050 right now and haven't really found a reason to get a 1920x1080 monitor yet. Maybe someone can convince me otherwise?
9. WHEN do you plan to build it?
Next month, August 2011.
None
Yes
