Ricemarine
So, I'm taking a tour in Canada right now. Now, I'm new to having data (used to be on t-mo w/o) with unlimited data/minutes with free roaming. So, my assumption is that the free roaming applied to Canada... Aha... domestic only.
In Canada, I used about 45-50 minutes of sprint tv to watch the World Cup (totally isn't worth it since Germany lost). So... I assume it's going to be around 60-70mb used, which will calculate with the rate of $0.002/kb which will be around $145 worth of fees.
After I realized this... very costly mistake... I called CS in which they told me that... 1... Sucks to be you... 2... yeah you probably won't have any luck getting those charges disputed... 3... Sprint TV uses a lot of bandwidth and 4... it will take 1-2 billing cycles before it shows up on my bill...
Any tips for helping me out?
I <3 ATOT.
Update #1
Actually, as said in post #5, it's going to be $450.
Update #2
Once again, big miscalculation. After doing some experimenting to calculate the data usage, I learned that one full game on Sprint TV was about 90 Mb. The updated bill charged me for about 44 Mb. So, I looked further into it and realized that the bandwidth was limited because of the CDMA2000, meaning at most I'd get around 60-100kbps in real world applications. So, using 100 kbps as my rate, the total cost would be about $90, which was how much I'm being charged! Luckily I was not in an EVDO zone so... yeah! Lesson learned... Data off in Canada.
I <3 ATOT.
Update #1
Update #2
