I am under the assumption that if my master cylinder were to be leaking internally the pressure differential between the two pistons should cause the brake warning light on my dash to illuminate? Is this correct? I know the light works because several years ago I had a bleeder plug wiggle open and the light alerted me of it.
The issue is my brake pedal is very spongy. If I leave a constant pressure on the pedal it does not sink further. From what I understand this points to air in the lines, not an internally leaking master cylinder. But I had a full flush of the brake system last summer and I had the same sponginess before and after the flush so I would be surprised there is still air in the system.
