I'm using a Gigabyte ep45-ud3p motherboard, Vista 64, & the onboard Realtek GigE LAN ports. These are paired with the 64b drivers on the PC and a Netgear VPN router. The wired connectivity to the rest of my house (wireless access points, other wired computers, Tivos, etc.) all work without any problems. However, the wired connection to this computer drops after ~2 minutes. When this occurs, it requires a disable/enable of the Realtek hardware -or- an unplug / replug of the cable to the port ('re-acquire IP' in Vista troubleshooter does NOT work). I have tried other ports on the router and the behavior remains the same. I have also tried the 'LAN2' port on the motherboard and the same problem exists. Has anyone else experienced this kind of connectivity issue? Is it likely the driver or is it a Realtek/Netgear HW conflict? Thanks!
Greg
Greg
