Baasha
For the past month or so, my X58 system has been freezing intermittently. This first happened in Win 7 x64 SP1 and then started happening on Win 8 Pro x64.
Win 7 is installed on a 2x SSD RAID-0 array and Win 8 is installed on a "regular" 7200RPM HDD.
At first, the computer was freezing even in Safe Mode! Then, I logged into Win 8 and then ran SFC /SCANNOW on the C-drive (Win 7) and it was able to complete without freezing.
It says it found corrupt files but is unable to fix them. I ran it several times and it keeps giving the same result.
It seemed to be fixed and then a week later, same thing. This has happened four times now - freezing, run SFC /SCANNOW several times, works okay for a few days, then freezing again.
I've run MalwareBytes, virus scans, ComboFix etc. to no avail - this keeps happening every few days.
I don't know what's causing the system files to keep getting corrupted! Could the SSDs be failing? If that's the case, why does it happen on Win 8 (regular HDD) as well?
I got these SLC SSDs in May 2009 - are they in their last throes?
I have an "SFCDETAILS.TXT" file but it's almost 60MB in size! I can't attach it here but some of the lines in there are like this:
Microsoft-Windows-Migration-ReplacementManifests-ds, Version = 6.2.9200.16384, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, file is missing
2013-07-18 10:51:23, Info CSI 00011b77 [SR] Cannot repair member file [l:20{10}]"wclWdi.dll" of Microsoft-Windows-Wcl, Version = 6.2.9200.16384, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, file is missing
2013-07-18 10:51:23, Info CSI 00011b78 [SR] Cannot repair member file [l:56{28}]"register-cimprovider.exe.mui" of Microsoft-Windows-WMIV2-Register-CimProvider-exe.Resources, Version = 6.2.9200.16384, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, file is missing
App-Host.Resources, Version = 6.2.9200.16384, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"sv-se", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, file is missing
