Alright, this problem has been around for a bit, but is slowly getting worse and I'm really at a loss as to what's happening. I have some thoughts, but I don't want to go buying more hardware until I'm more sure what might be the problem. Here's the jist of it:
System:
Asus A7N8X - Deluxe, rev 1.04, Bios 1008
Athlon XP 2600+ 333
corsair 2X512 2700
Antec 550W Power Supply
80G WD Special Edition
Pioneer 104S CD/DVD Player
LG CDR/RW
GeForce 6800GT
Alright, the problem started with Windows failing to start on occasion. It would boot to the Windows loading screen where the blue rectangles would move across the window and then just stop. When this happened it would always boot up fine on a reset. I went to some effort and got everything totally up to date, cleaned out any old drivers and just made sure the system was in good shape. It ran without any problems for a bit.
Then I purchased a WD Raptor SATA 74G Hard Drive. Seemed to be good and managed to format it and install windows and everything seemed good. Oh, I updated my Bios to 1008 just prior to installing this HD. Anyway, I again started having problems at startup. Only this time it would stop earlier, at the Raid setup screen, and sometimes earlier at the detecting IDE devices screen. Seemed to be a hard failure as it failed to start on about 5 or 6 bootup attempts.
I removed the WD Raptor drive and suddenly it would boot up fine again on the IDE drive. Okay, I figured the Raptor went bad. Pulled it and was ready to send for a replacement.
Now, this morning, it failed to boot again on the IDE drive. On several attempts, first time the screen just went blank and never came back, this was at the point where the loading windows should have started. Next attempt, it stopped at the Raid setup again, but I noted that the two fans I have connected to the "fan only" power supply connector stopped as well at this point. Next attempt, it stopped during post again, but when it stopped, the power led on my case started blinking. Couldn't find anything in the mobo manual about a blinking led. Next boot attempt, it came up normally again.
Okay, so I didn't mail my Raptor back. I don't think that was the problem anymore. I'm suspecting the power supply, or the motherboard now. Oh, I've run memtest and it passed over and over for 9 hours straight, so I'd say my memory is good.
I'm at a loss as to how to troubleshoot this problem. I don't want to run out and purchase a power supply or a motherboard without knowing which is the problem. Any ideas?
Thanks in advance for the help
System:
Athlon XP 2600+ 333
corsair 2X512 2700
LG CDR/RW
GeForce 6800GT
