Intermittent LAN Connection (Wired)
Perfection
40
Hi,
I am the network administrator at a fraternity, where now that we are headed back to school, people are having computer problems. To make matters worse (with respect to me), the house recently underwent a remodel job, without them updating the electrical wiring, which I would have appreciated.
Anyways, one of the guys was using his computer over the LAN, left and came back. When he returned, his Dell laptop said it didn't have a LAN connection (cable unplugged...something of that nature).
We then switched his port with that of his roommate. This computer, a Sony Vaio, said it had a connection and was attempting to acquire an address for a few seconds, before then becoming disconnected for a few seconds (it cycles though these states).
The way this cable is connected is that it goes from the computer >> wall >> rack punchdown >> Dell Switch >> Linksys Router >> Comcast.
When I take this connection and remove the Dell Switch from the list (ie directly connect to the Linksys Router), it does not do this state cycling.
Do I have a bad cable....and where would it be. Obviously it isn't the user side computer or cable, since it affects more than one set of each. Also, I tried multiple cables in the network closet, which I know work, so that doesn't seem to be the cause either.
What could have caused this strange behavior...I'm really desperate for answers at this point.
Thanks so much in advance.
- J
JRock
2,742
Have you tried going from their port the patch panel to a different port on the switch?
What about them directly connected to that port on the switch?
Try a firmware upgrade on the switch as well. (Prob wont fix the issue but you mas as well be running the most current)
edit: Confirm the port on the switch is free of debris and has no bent pins.
