- May 28, 2007
- 3,999
- 63
- 91
Gf's parents have a 07' Pontiac G6 base model with the 4 banger. In this last month the Check Gas Cap alert has flashed up on the radio display, and the only way to fix it is to pull over and fully loosen (with a loud hiss of pressure when I do), then fully tighten the gas cap. That's the only way I can get the message to disappear. It's completely random, but on average 1 out of 8 trips to town it'll do it. The trips are about 8 miles each time, very few bumps, all asphalt driving, mostly in the 35mph - 60mph area. The car does have warranty (extended manufacturer), but with the problem so intermittent we're trying to see a starting point to look into the problem.
Really appreciate the help!
EDIT: Oh and to follow guidelines, no modifications, oil changes at about every 5,000 miles, and it just turned 29,000 on the ODO.
