yllus
Elite Member & Lifer
The idea for this topic originally sprang from another post that didn't get much attention, but here's the URL:
http://forums.anandtech.com/messageview.cfm?catid=36&threadid=673206
To sum up the problem:
Low bandwidth usage like websurfing is responsive and free of problems, but either putting a heavy load on the line in terms of speed or in terms of connections made cuts out service. At that point, one must unplug and plug the cable modem back into the wall, wait for the modem to reinitialize - and then everything is working just fine again.
Now because another person seems to be resetting the router only and not the cable modem, and getting back online that way, this sounds to me like a widespread problem with Rogers itself. I've had the problem with Windows 95B and 2000 Pro SP2, between two different network cards and two machines. A friend in North York (I'm way over in Mississauga) has the exact same problem in Windows 2000 Pro SP2 as well. My list of suspects goes like this:
1. A problem with Rogers' network that drops us when we get busy.
2. Multiple versions of Windows handling our connections badly.
3. Widespread NIC driver problems.
#2 and #3 are extremely unlikely in my view, so I'm guessing this is Rogers' fault. However I'm also willing to entertain the notion there's something we need to tweak/hack in Windows to get this fixed. For those in the forum familiar with Win2k network architechture, what exactly happens when Windows detects a network disconnection and later a reconnection? I get a little icon in the system tray that indicates Windows DOES know there was a momentary disconnection while I reboot the cable modem. Is Windows resetting something that perhaps messed up that is causing this problem in the first place?
