FeuerFrei
Instead of booting up Windows 7, my pc saw fit to run Startup Repair utility (tool that comes with Windows) ... ostensibly to fix problems keeping my pc from booting. Not sure what prompted this - never had a problem before. My last actions before this, were copying many gigabytes of files to a USB flash drive for backup purposes, then shutting off the computer.
Windows 7 is installed to a classic mechanical hard drive that survived a power surge 10 weeks ago (lightning), and it's been running normally for six weeks.
How long should the Startup Repair task take to finish on a 500 GB drive? I let it run for 21 HOURS, before shutting off the system forcefully. It never completed. It seems to hang on "Attempting to repair ...". BUT it could be just slow, I've no way of knowing. The hard-drive-activity indicator light stays almost perpetually on.
Hope I haven't damaged anything by aborting the process multiple times. BUT I can't START WINDOWS NORMALLY, even if I select that option at the outset. Frustrating. Whether I choose option 1) "Run scan (recommended), or option 2) "Start Windows normally" ... the pc just fires up the Startup Repair scan no matter what I choose.
IT ALSO, disables the mouse and keyboard during the scan so I can't hit the "CANCEL" button or anything.
So now I'm stuck waiting indefinitely for the scan to end. Don't want to wear out the hard drive. Been 19 hours so far ... I've not noticed any reboots during the repair process ... though I don't monitor it 24/7.
